[GRASS5] compiling on solaris
Helena
hmitaso at unity.ncsu.edu
Tue Mar 20 15:00:32 EST 2001
Markus,
this is the error message for the Solaris8 compile
Helena
I did what was suggested, here is the error messages
SKAGIT>gmake5
SRC = /home2/usr/local/grass/src
CMD = /home2/usr/local/grass/src/CMD
HEADER = head.sparc-sun-solaris2.8
ARCH = sparc-sun-solaris2.8
GISBASE = /home2/usr/local/grass/dist.sparc-sun-solaris2.8
VERSION = 5.0beta12 February 2001
/home2/usr/local/grass/src/libes/gis
make -f OBJ.sparc-sun-solaris2.8/make.rules
gcc -g -O2 -I/home2/usr/local/grass/src/include -I/usr/include -c error.c -o
OBJ.sparc-sun-solaris2.8/error.o
error.c: In function `G_fatal_error':
error.c:72: `__builtin_va_alist' undeclared (first use in this function)
error.c:72: (Each undeclared identifier is reported only once
error.c:72: for each function it appears in.)
error.c: In function `G_warning':
error.c:87: `__builtin_va_alist' undeclared (first use in this function)
*** Error code 1
make: Fatal error: Command failed for target `OBJ.sparc-sun-solaris2.8/error.o'
Dave
Markus Neteler wrote:
> Helena,
> On Tue, Mar 20, 2001 at 11:58:17AM -0500, Helena Mitasova wrote:
> > We have tried to compile the latest CVS snapshot (March 19) on
> > Sun Ultra 10 with Solaris 8 and we got lot of errors - mostly
> > due to the following:
> > gcc: /home2/usr/local/grass/src/libes/LIB.sparc-sun-solaris2.8/libgis.a:
> could you try
> cd grass/src/libes/gis
> gmake5
> and tell me the error? I am quite sure that flate.c breaks (this indicates
> that zlib/headers are not found.
> Just a guess
> Markus
> PS: I'm back here...
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
