[GRASS5] Tag test 2
Markus Neteler neteler at geog.uni-hannover.de
Tue Mar 20 15:09:12 EST 2001
Hi all,
as I have tagged some missing directories for the stable tag
procedure tests, you will have to update your separate
"grass testbranch_5_0_0stable" tree like this:
cd testbranch_5_0_0stable  # or whatever
cvs up -dP -r testbranch_5_0_0stable
(if you already checked it out).
Cheers
 Markus
PS: For clarification: The cvsbranch.sh is only used to set the tags,
nothing else. So usually you won't run it. I just wanted to simplify
my tagging life.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
