[GRASS5] Re: [bug #223] (grass) d.zoom segfaults
grass at geni.cemtlo.com
Tue Mar 20 19:19:52 EST 2001
> From neteler at geog.uni-hannover.de Wed Mar 21 02:21:02 2001
> Date: Tue, 20 Mar 2001 17:45:00 +0000
> From: Markus Neteler <neteler at geog.uni-hannover.de>
> To: grass5 at geog.uni-hannover.de
> Subject: Re: [GRASS5] Re: [bug #223] (grass) d.zoom segfaults
> Hi Huidae,
> you changed src/libes/gis/find_file.c recently to fix the
> i.in.erdas. Do you have a recommendation for below proposal
> from Job?
> Thanks
> Markus
> On Tue, Mar 20, 2001 at 01:07:01PM +0100, spijker at geo.uu.nl wrote:
> > On Mon, 19 Mar 2001, Request Tracker wrote:
> > > d.zoom segfaults direct after startup without any message.
> > > region is :
> > > CURRENT REGION: N=431250 S=350000 RES=250 ROWS=325
> > > E= 80000 W= 13000 RES=250 COLS=268
> > It seems the bug was caused by a library call in
> > src/libes/gis/find_file.c. A string was copied to an empty string wich
> > caused the segfault.
> > The solution (or: my solution) is the following diff for find_file.c. I
> > can submit it to the CVS but I don't like to mess with libraries and I
> > don't know if there is a 'philosophy' behind the original method.
> > 54c54,56
> > < strcpy(mapset, xmapset);
> > > if (!mapset=="") {
Hi Markus,
I see. I'm correcting it. :-)
Regards,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
