[GRASS5] r.in.gdal's problems with projections is G_get_window
()problem.
Eric G. Miller
egm2 at jps.net
Sat Mar 17 02:31:43 EST 2001
On Sat, Mar 17, 2001 at 01:15:25AM -0500, Frank Warmerdam wrote:
> Eric,
> GDAL does support (to a limited extent) Arc/Info .prj files with
> arc/info grids (binary and ascii), but not with tiff files. I haven't
> actually seen this many times. It could be easily added though, if this
> is of wide interest.
I dunno, maybe. I understand the newer ArcView is also supposed to
understand .prj files (but maybe GeoTIFF as well ...).
> GDAL does support tiff world files, though I think the GeoTIFF info
> takes precidence if it is there. Perhaps this is your problem. Your
> world file is being ignored because there is some sort of dummy GeoTIFF
> information in the file.
Well, I just ran some tests to see if that was the problem. Nope. While
the tiff file in question had some geotiff tags without projection info,
I converted it to a xpm file then back to a geotiff file which seemed to
remove all the geotiff stuff. Now, listgeo shows:
$ listgeo tifftest.tif
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
Corner Coordinates:
... unable to transform points between pixel/line and PCS space
But with:
GRASS> r.in.gdal -o input=tifftest.tif output=tifftest
GRASS> r.info tifftest
| Layer: tifftest Date: Fri Mar 16 23:07:23 2001 |
| Mapset: snows Login of Creator: felix |
| DataBase: /home/felix/gis.d |
| Title: ( tifftest ) |
| Type of Map: raster Number of Categories: 255 |
| Data Type: CELL |
| Rows: 1426 |
| Columns: 1140 |
| Total Cells: 1625640 |
| Projection: UTM (zone 10) |
| N: 1426 S: 0 Res: 1 |
| E: 1140 W: 0 Res: 1 |
| Data Source: |
| Data Description: |
| generated by r.in.gdal |
As you can see, the resolution values and raster extents of the tiff world file
are not being used.
$ cat tifftest.tfw
0.38876593293013
0.00000000000000
0.00000000000000
-0.39782634201703
702567.88102749444000
4287537.86842568960000
I'm not sure what the problem is, but apparently GDALGetGeoTransform() in main.c
is not coming up with the affine parameters???
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
