[GRASS5] sockets question
strobe anarkhos
anarkhos at mac.com
Thu Mar 15 01:54:48 EST 2001
At 9:42 AM +0700 3/15/01, Justin Hickey wrote:
>Hi
>strobe anarkhos wrote:
> > I'm using GRASS 5 as my base and thus am using fifos in a fully
> > compatible fashion to other grass5 display drivers. To my knowledge
> > the developmental version 5.1 is using sockets instead of fifos to
> > connect the display commands to the servers.
>Sorry, I can't really help with your sockets question. Eric Miller is
>our expert on that, he should reply soon. However, I would just like to
>clarify things with the socket code with regards to the versions of
>Grass. The sokect code is now the default method for process
>communication for version 5.0. So, if you download the current CVS and
>compile, you will be using the new socket code. If no major problems
>occur when we release version 5.0, we plan to remove the fifo code from
>the tree. Since your changes will be used for version 5.1, I suggest you
>concentrate on the socket code, unless somebody requests fifo code.
>Hope this helps save you some work. :-)
I'm not going to use it unless it's working 100%. I'm not interested in debugging sockets, I only want to extend the display driver function set. Fifos currently work so that's what I'm currently using.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
