[GRASS5] sockets question
Justin Hickey jhickey at hpcc.nectec.or.th
Wed Mar 14 21:42:37 EST 2001
Hi
strobe anarkhos wrote:
> I'm using GRASS 5 as my base and thus am using fifos in a fully
> compatible fashion to other grass5 display drivers. To my knowledge
> the developmental version 5.1 is using sockets instead of fifos to
> connect the display commands to the servers.
Sorry, I can't really help with your sockets question. Eric Miller is
our expert on that, he should reply soon. However, I would just like to
clarify things with the socket code with regards to the versions of
Grass. The sokect code is now the default method for process
communication for version 5.0. So, if you download the current CVS and
compile, you will be using the new socket code. If no major problems
occur when we release version 5.0, we plan to remove the fifo code from
the tree. Since your changes will be used for version 5.1, I suggest you
concentrate on the socket code, unless somebody requests fifo code.
Hope this helps save you some work. :-)
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
