[GRASS5] r.contour update
Andrea Aime aaime at comune.modena.it
Mon Mar 12 09:26:21 EST 2001
Justin Hickey already did that. :-)
Just grab again r.contour from CVS, but beware, we are still
working on it, so in the next days we may release a new version.
(btw, if anyone wants to collaborate he would be welcomed ;-) )
Bye
Andrea Aime
Bob Covill wrote:
> Andrea,
> I grabbed the r.contour yesterday and gave it a test run. It seems to
> work quite nicely.
> I just have a comment or question about compiling.
> Of course it compiled fine under Linux. It gave me a bit of a problem
> under Solaris (7). The problem was the definition of DBL_EPSILON. I
> believe this is defined in float.h. The float.h file is referenced under
> Linux from math.h which is good. It is not referenced by math.h under my
> Solaris. I simply added include float.h to the source (main.c) and it
> built and worked fine on Solaris.
> Could the definition of DBL_EPSILON be added directly to the code to
> avoid dependancies or does its definition vary between platforms?
> Bob Covill
> Tekmap Consulting
> P.O. Box 2016 Fall River, N.S.
> B2T 1K6
> Canada
> E-Mail: bcovill at tekmap.ns.ca
> Phone: 902-860-1496
> Fax: 902-860-1498
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
