[GRASS5] r.contour update
Bob Covill
bcovill at tekmap.ns.ca
Mon Mar 12 07:58:24 EST 2001
Andrea,
I grabbed the r.contour yesterday and gave it a test run. It seems to
work quite nicely.
I just have a comment or question about compiling.
Of course it compiled fine under Linux. It gave me a bit of a problem
under Solaris (7). The problem was the definition of DBL_EPSILON. I
believe this is defined in float.h. The float.h file is referenced under
Linux from math.h which is good. It is not referenced by math.h under my
Solaris. I simply added include float.h to the source (main.c) and it
built and worked fine on Solaris.
Could the definition of DBL_EPSILON be added directly to the code to
avoid dependancies or does its definition vary between platforms?
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
