[GRASS5] d.rgb and i.composite differences
Bernhard Reiter
bernhard at intevation.de
Mon Mar 12 06:14:40 EST 2001
On Mon, Mar 12, 2001 at 05:46:12PM +0700, Justin Hickey wrote:
> So, if we are fairly sure about the socket code as default (if you want
> to remove the IPC and fifo code, then I would suggest to do this before
> the branch OR, leave the IPC and fifo code in for this release and
> remove it from the main branch after the release branch is created),
I suggest leaving the fifo code in as a fallback.
> Although we still need a clearly defined method for
> submitting bug fixes to the release branch (what to tag, how to tag,
> when to tag, etc).
Tagging is very important when we do merges.
So we have to tag before and after a merge in both branches.
Bug-fixes should be done in one commit, so we can use the date to
distinquish them.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010312/858ce93b/attachment.bin
