[GRASS5] Angle of Line Function?
Eric G. Miller
egm2 at jps.net
Sat Mar 10 18:12:01 EST 2001
On Sat, Mar 10, 2001 at 02:04:23PM -0800, Eric G. Miller wrote:
> On Sat, Mar 10, 2001 at 04:25:20PM -0400, Bob Covill wrote:
> > Jeshua Lacock wrote:
> > > Greetings,
> > > I would greatly appreciate any help with developing a simple function
> > > that returns the angle (in degrees) of a line when given two points
> > > (x1, y1 and x2, y2).
> > > Embarrassingly I have spent days trying to figure this out (that's
> > > what I get for using the teachers edition of geometry in high
> > > school!!). ;->
> > > I have ran across a function on the web, but somehow it seems really off:
> > > angle = (((Atan((northingDifference/eastingDifference)))*180)/PI)
> Arctan() will give you an acute angle. You would need to know the
> quadrant the line is in (assuming the first point as the origin) to add
> a correction factor.
> Assuming (0 == North, 90 == East, etc...):
> // Sorta code...
> dy = (y2 - y1);
> dx = (x2 - x1);
> if (dy > 0.0 && dx > 0.0) {quadadjust = 0.0;}
> else if (dy > 0.0 && dx < 0.0) {quadadjust = 360.0;}
> else if (dy < 0.0 && dx > 0.0) {quadadjust = 180.0;}
> else if (dy < 0.0 && dx < 0.0) {quadadjust = 180.0;}
> else {
> if (dx == 0.0) {slope = (dy > 0.0) ? 0.0 : 180.0;}
> else if (dy == 0.0) {slope = (dx > 0.0) ? 90.0 : 270.0;}
> else {/* huh? */}
> return slope;
> slope = ((atan(dy/dx) * 180) / M_PI) + quadadjust;
> return slope;
> // End.
> Note, I haven't really checked the above... And floating point numbers
> can be weird in comparisons, so maybe an EPSILON is needed...
> I understand there are better ways to do this than using atan() which
> can be expensive...
Sorry, the above is *not correct*.
I think the below would work...
dy = y2 - y1;
dx = x2 - x1;
assert (!(dx == 0.0 && dy == 0.0));
if (dx == 0.0) /* Special case, vertical line */
if (dy > 0.0)
return 0.0;
else
return 180.0;
if (dy == 0.0) /* Special case, horizontal line */
if (dx > 0.0)
return 90.0;
else
return 270.0;
if (dx > 0.0)
return 90.0 - atan(dy/dx) * (180 / M_PI);
else if (dx < 0.0)
return 270.0 - atan(dy/dx) * (180 / M_PI);
exit (EXIT_FAILURE);
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
