[GRASS5] Current sockets bug
Eric G. Miller egm2 at jps.net
Fri Mar 9 11:37:59 EST 2001
On Fri, Mar 09, 2001 at 01:43:47PM +0000, Markus Neteler wrote:
> Hi all,
> it seems I got an idea about the sockets bug:
> - It occurs in
> src/display/devices/XDRIVER/XDRIVER24/SWIZCHER.c
> The call should be
> Usage: x0 [nlev]
> but
> argv[1] is:
>  /data3/grass5/grass5/dev/fifo.1a /data3/grass5/grass5/dev/fifo.1b
> at that position (test around line 118ff).
> As fifos are not required, something must be wrong here.
> Hopefully someone gets it fixed...
It's in d.mon/pgms/start.c (run2()).  I think the define of USE_G_SOCKS
got missed in the configure.in somehow.  Fix that, and the problem
should disappear.  I'll try to look at it this weekend.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
