[GRASS5] grass cvs snapshot from 26. Feb.
Markus Neteler neteler at geog.uni-hannover.de
Fri Mar 9 12:05:59 EST 2001
On Fri, Mar 09, 2001 at 08:14:04AM -0800, Eric G. Miller wrote:
> On Fri, Mar 09, 2001 at 09:20:18AM +0000, Markus Neteler wrote:
> > I checked the XDRIVER directory but could find any problem.
> > May it be related to README.xdriver? Or did we miss anything
> > when making sockets default? It seems not to work since
> > sockets are default.
> You didn't miss the AC_DEFINE(USE_G_SOCKS) in the --with-socket case
> statement in configure.in?  It seems that the define is not being set.
> Therefore, the wrong code is being compiled in d.mon/pgms/start.c.
> Sorry, haven't gotten a chance to update my CVS since sockets was made
> the default.
Thanks for the hint. It seems to be a bug in configure!
As the socket is default, I didn't specify --with-socket.
Maybe that's the problem (position of USE_G_SOCKS in configure).
I try to find out,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
