[GRASS5] grass cvs snapshot from 26. Feb.
Markus Neteler
neteler at geog.uni-hannover.de
Fri Mar 9 12:12:12 EST 2001
Hi all,
it seems I got it. Thanks to Eric for the hint, the
AC_DEFINE(USE_G_SOCKS)
was only set when --with-socket was specified. I
have added it to another position in
configure[.in]
where XDRIVER=socket is defined. Now the USE_G_SOCKS is
always defined.
Still I propose to remove the fifo/ipc stuff to clean
up the situation. Note that binaryInstall.src needs to
be updated for sockets. Currently
make bindist
will produce a corrupted package. I think I'll modify
that now as Justin will be back on Monday only.
Cheers
Markus
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
