[GRASS5] Problem with sockets on Linux
Andrea Aime aaime at comune.modena.it
Fri Mar 9 02:49:02 EST 2001
No, the server is not running, I can't find any new process (I don't
know the driver name (is it simply "xo"?), but if you sort processes
by PID you see if something has been created after grass start).
The following "d.mon select=x0" of course does not work and returns
the same error.
Hope this helps
Andrea
PS: which server ports are used by the X driver? Maybe it finds them
occupied by another application (I use 4444/6001/7001 for an in-house
application...). Anyway, I think that server ports numbers should be
configurable...
> On Thu, Mar 08, 2001 at 09:36:13AM +0000, Markus Neteler wrote:
> > On Thu, Mar 08, 2001 at 09:00:37AM +0100, Andrea Aime wrote:
> > > I've tried make distclean, but without success, I always get the
> > > same error. Before "make distclean" I also deleted my installation
> > > directory and my .grassrc5. Please note that I install with a different
> > > prefix (that should not make any difference, but I don't understand
> > > where the error is). Any other ideas? Some way to get more detailed
> > > error logs?
> > > Bye
> > > Andrea
> > To confirm: The same problem occurs on SUN/Solaris. No effect with
> > make distclean and a complete re-compile (I tried twice). There must
> > be a recent bug... (another reason to clean out the unused driver stuff).
> Is the server running (or did it exit)? (try "ps aux | grep <driver>").
> Does following with a "d.mon select=<DRIVER>" succeed? (the timing
> issue...).
> Eric G. Miller <egm2 at jps.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
