[GRASS5] grass cvs snapshot from 26. Feb.
Justin Hickey jhickey at hpcc.nectec.or.th
Fri Mar 9 03:25:54 EST 2001
Hi Eric
"Eric G. Miller" wrote:
> On Thu, Mar 08, 2001 at 02:26:33PM +0000, Markus Neteler wrote:
> > > I can start the PNG driver only once, after that i get an error
> > > message that the socket is already in use. Only rm
> > > $LOCATION/.tmp/'hostname'/PNG helps. Are there any problems to
> > > expect with mounting the $GISDBASE via NFS?
> > > This is my setup here.
> > Hi Eric...
> You are stopping the monitor before you try to restart?  As far as
> NFS goes -- UNIX sockets may be a problem.  I think it depends how
> you're using NFS (is your data local?).  I don't think UNIX sockets
> are guaranteed to work over NFS, so if your mapset is on an NFS share
> -- it could be a problem.  I have some code that will put the UNIX
> socket in $HOME/.grass/com -- but if $HOME is mounted on an NFS
> share, there still might be a problem.  Seems the only way to handle
> this would be to create the UNIX socket in the local /tmp directory.
> Since the processes would be local *and* the socket would be local,
> then there should be no problem.  I don't have an NFS setup, so I'm
> unable to test it.
This may not be an NFS problem. I tried to test Andreas's situation
(database directory mounted through NFS) and received similar errors.
Just for the heck of it, I tried running d.mon start=x0 with a local
database and received errors similar to what Andrea and Markus have
posted. To try to make sure I wasn't doing something wrong I decided to
try as clean a setup as possible. That is
create a new grass directory
create a new database directory
store a fresh version of spearfish in new database directory
get a complete checkout of grass
configure --enable-postgres=no
make
bin.ARCH/grass5
Then with the new database d.mon start=x0 gives
GRASS 5.0beta12 > d.mon start=x0
Usage: x0 [nlev]
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
So, I think the socket code is broken since I could use them without
problems before. Perhaps this is the same problem for Andreas' NFS
problem? Just thought I'd let you know.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
