[GRASS5] r.neighbors
Markus Neteler
neteler at geog.uni-hannover.de
Fri Mar 9 03:57:57 EST 2001
On Thu, Mar 08, 2001 at 03:55:38PM -0400, Bob Covill wrote:
> Markus Neteler wrote:
> > Hi Bob,
> > On Thu, Mar 08, 2001 at 03:27:09PM -0400, Bob Covill wrote:
> > > Hello,
> > > I have applied a couple changes to r.neighbors. I have updated the
> > > median option which was not working. It seems to be working now, but
> > > could use some testing.
> > thanks for the fix!
> > > I have also added a flag "-n" to reset zeros in the output raster to
> > > null. The default currently outputs all nan data to zero.
> > Would it make sense to have NULL as default output and Zero optional?
> > Most GRASS modules write NULL.
> > Regards
> > Markus
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Markus,
> I will flip the flag around and make it write NULL by default. The only
> potential problem is if the the raster contains real zeroes in which case -n
> would have to be set to avoid setting thwem to null.
Bob,
what about
-z: preserving zero values in calculation
Would this cover all side effects?
> If this is acceptable I will update the html man page as well.
> Bob Covill
Regards
Markus
