[GRASS5] grass cvs snapshot from 26. Feb.
Justin Hickey jhickey at hpcc.nectec.or.th
Thu Mar 8 21:31:21 EST 2001
Hi Andreas
Andreas Lange wrote:
> Hi Markus, hi all,
> i just want to report that i successfully compiled the CVS snapshot
> on IRIX with gcc.
> I had to edit the header file manually, as i am not able to
> fix the configure.in script i want to ask someone to edit
> configure.in in a way that makes the changes. There should IMHO never
> be an -I include directive on the compile line.
Well, then how could we point the compiler to the src/include directory?
I'm not sure what you mean here.
> The driver is not installed with make install
This indicates that it is not created under one of the dist.ARCH/
directories. Where is it installed after gmake5?
> Are there any problems to expect with mounting the $GISDBASE via NFS?
I don't think there should be. Once the disk is mounted it should appear
to be just another directory in the file system.
> I can no longer compile NVIZ2.2,
I'm not sure here. As of a CVS update on March 6, NVIZ compiled and runs
on our IRIX machine. Sorry, not much help here.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
