[GRASS5] r.neighbors
Bob Covill
bcovill at tekmap.ns.ca
Thu Mar 8 14:55:38 EST 2001
Markus Neteler wrote:
> Hi Bob,
> On Thu, Mar 08, 2001 at 03:27:09PM -0400, Bob Covill wrote:
> > Hello,
> > I have applied a couple changes to r.neighbors. I have updated the
> > median option which was not working. It seems to be working now, but
> > could use some testing.
> thanks for the fix!
> > I have also added a flag "-n" to reset zeros in the output raster to
> > null. The default currently outputs all nan data to zero.
> Would it make sense to have NULL as default output and Zero optional?
> Most GRASS modules write NULL.
> Regards
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Markus,
I will flip the flag around and make it write NULL by default. The only
potential problem is if the the raster contains real zeroes in which case -n
would have to be set to avoid setting thwem to null.
If this is acceptable I will update the html man page as well.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
Type: text/x-vcard
Desc: Card for Bob Covill
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010308/e48da228/bcovill.vcf
