[GRASS5] Autoconf and Cygwin - X11
Malcolm Blue mblue at nb.sympatico.ca
Wed Mar 7 17:49:39 EST 2001
Mike,
My installation looks like /usr/X11R6 (same as Andreas).  When I look at
it in Windows Explorer, it appears as X11r6, but that's a windows
"feature".
configure had no problem finding the X libraries and include files when
I ran it.
Did you untar the X11 tarballs in a cygwin shell?  The only time I had
problems like that, was when I used winzip to uncompress and untar and
archive.
Malcolm
Mike Thomas wrote:
> Hi Andreas.
>> on my cygwin installation with the X11R6 setup there is no directory
>> "/usr/X11r6". My X11 installation resides under /usr/X11R6 (note the upper
> "R"!). Do
>> you have the XFree86 4.01 Version from
>> http://sources.redhat.com/cygwin/xfree/ ?
> It's at work (I've been using Grass rather than working hard!), But I got it
> from the link in the compiling Cygwin instructions.  It untars with a small
> r for me.
>> Do you use Windows NT 4.0 or Windows 2000 Prof.? Windows 9x is not
> supported
>> with this setup. And the setup will only work with NTFS or FAT32!
> It was on an NT machine with NTFS.  As I need WIn98 at home for music
> recording, I will continue to try and make Grass work there - if necessary
> focussing on the PS.MAP and CELL modules.
> I can confirm that Grass fired up a (sockets) monitor with the Nutcracker
> DEC XServer under NT, but I haven't done much more on that machine.
> Cheers
> Mike Thomas.
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
