v.out.xfig (was: Re: [GRASS5] wrapper for awk?)
Michel Wurtz mw at teledetection.fr
Wed Mar 7 11:03:31 EST 2001
mlennert at ulb.ac.be wrote:
> I still have the problem that some of the files are not readable at all by xfig. If I see the pattern correctly it seems to be because v.out.xfig writes the coordinates in exponential format (7.67352e+11 4.57982e+11). Since xfig fails in those lines, I suppose that must be the problem.
> I also have a file (with "normal" coordinates) where I get no error
> MAP SCALE:    1
Here is the problem : v.out.xfig draw at a "1" scale, and does
not verify wheter at this scale the document will fit or not
on an A4 sheet of paper !
Use 100 in your test file and you will see the drawing
For the other files, use v.digit to change the scale.
BTW, I think that the "SCALE" of a vector map has nothing to do
with the print scale, which should be a parameter of v.out.xfig
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
