[GRASS5] open GRASS in own xterm
Eric G. Miller
egm2 at jps.net
Tue Mar 6 11:23:46 EST 2001
On Mon, Mar 05, 2001 at 04:50:39PM +0100, Bernhard Reiter wrote:
> On Mon, Mar 05, 2001 at 04:24:56PM +0000, Markus Neteler wrote:
> > Hi all,
> > as new users tend to start "grass5" with a double click in
> > a file explorer (especially the (former) Windows users) it
> > might be a good idea to start GRASS in an own "xterm" *if*
> > the DISPLAY variable is set (= Xwin running). This click-idea
> > of course doesn't currently work.
> Dont't,
> this is a task which the file manager has to solve.
> You can set the right options there.
> GRASS cannot do much about.
> (And it should not try.)
I agree with Bernard here. This is not a problem for GRASS to solve.
Here in Debian GNU/Linux land, there's a slick "menu" program that
handles this nicely:
file: /etc/menu/grass
?package(local.grass):\
needs=text\
section="Apps/Local/GRASS"\
title="GRASS 5.0b12"\
command="/usr/local/bin/grass5"\
icon="/usr/local/share/pixmaps/grass_sm.png"
$ update-menus
And, voila, "GRASS 5.0b12" shows up in every window manager menu, *and*
will be started in a terminal emulator if running under X.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
