[GRASS5] Autoconf and Cygwin - X11
Andreas Lange A.C.Lange at gmx.net
Tue Mar 6 17:16:55 EST 2001
Hi Mike,
on my cygwin installation with the X11R6 setup there is no directory
"/usr/X11r6". My X11 installation resides under /usr/X11R6 (note the upper "R"!). Do
you have the XFree86 4.01 Version from
http://sources.redhat.com/cygwin/xfree/ ?
Do you use Windows NT 4.0 or Windows 2000 Prof.? Windows 9x is not supported
with this setup. And the setup will only work with NTFS or FAT32!
HTH,
Andreas
Sent through GMX FreeMail - http://www.gmx.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
