[GRASS5] Autoconf and Cygwin - X11
Mike Thomas
miketh at brisbane.paradigmgeo.com
Mon Mar 5 19:26:44 EST 2001
Hi all.
On Cygwin, autoconf generates a configure script which doesn't find the X11
libs and headers in their default location "/usr/X11r6" (note the small r).
A patch to partially solve this problem (searches for certain utility
libraries such as OpenGL and PNG) is below.
I say partially because the script still fails to find X itself, which means
that XINCPATH and XLIBPATH need to be manually edited in the head file:
checking how to run the C preprocessor... (cached) gcc -E
checking for X... (cached) no
checking for ANSI C header files... (cached) yes
Unfortunately I don't know yet how autoconf looks for X - it seems to be the
AC_PATH_XTRA line in configure.in.
Cheers
Mike Thomas.
Index: configure.in
RCS file: /home/grass/grassrepository/grass/configure.in,v
retrieving revision 1.54
diff -r1.54 configure.in
215,216c215,216
< my_inc_dirs="/usr/include /usr/local/include /usr/X11R6/include
/opt/include /usr/freeware/include"
< my_lib_dirs="/usr/lib /usr/local/lib /usr/X11R6/lib /opt/lib
/usr/freeware/lib"
/usr/X11r6/include /opt/include /usr/freeware/include"
> my_lib_dirs="/usr/lib /usr/local/lib /usr/X11R6/lib /usr/X11r6/lib
/opt/lib /usr/freeware/lib"
828c828,829
< /usr/X11R6/include /usr/X11R6/include/GL /opt/Mesa/include"
> /usr/X11R6/include /usr/X11R6/include/GL \
> /usr/X11r6/include /usr/X11r6/include/GL /opt/Mesa/include"
857c858
< /usr/local/Mesa/lib /usr/X11R6/lib /usr/local/X11/lib \
> /usr/local/Mesa/lib /usr/X11R6/lib /usr/X11r6/lib /usr/local/X11/lib \
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
