[GRASS5] Tcltkgrass - r.in.bin interface needs updating
Mike Thomas
miketh at brisbane.paradigmgeo.com
Mon Mar 5 19:09:00 EST 2001
Hi all.
Using the 26 February snapshot I noticed two problems in the interface to
r.in.bin.
1. There is no way of setting the -b (byte swapping) and -h (header)
switches. The -b switch is essential on Intel platforms to importing
GTOPO30 DEMs.
2. The title field passes titles with spaces through to r.in.bin so that,
for example, "Eastern Australia" causes r.in.bin to complain about
"Australia" not being a valid command line switch.
As these are probably symptomatic of more widespread issues I am leaving
them to the maintainer of Tclktkgrass.
Cheers
Mike Thomas.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
