[GRASS5] open GRASS in own xterm
Bernhard Reiter
bernhard at intevation.de
Mon Mar 5 10:50:39 EST 2001
On Mon, Mar 05, 2001 at 04:24:56PM +0000, Markus Neteler wrote:
> Hi all,
> as new users tend to start "grass5" with a double click in
> a file explorer (especially the (former) Windows users) it
> might be a good idea to start GRASS in an own "xterm" *if*
> the DISPLAY variable is set (= Xwin running). This click-idea
> of course doesn't currently work.
Dont't,
this is a task which the file manager has to solve.
You can set the right options there.
GRASS cannot do much about.
(And it should not try.)
> Starting GRASS in its own xterm would reduce lot of confusion
> for them... Any objections?
> We could use the same check mechanism already used for the
> graphical startup.
> Regards
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010305/95adc766/attachment.bin
