[GRASS5] Re: Known Solaris 7 issues with beta 11]
Federico Ponchio ponchio at ruffini.dm.unipi.it
Mon Mar 5 08:19:48 EST 2001
On Mon, 5 Mar 2001, Markus Neteler wrote:
> Hi Federico,
> hi all,
> > 2) solaris tar is quite stupid:
> > 	tar cBf - bin/  gives error while
> > 	tar cBf - bin   is ok (yes its the slash at the en the problem
> > so it wont install unless i do not modify the Makefile accordingly.
> Does
>  tar cBf - bin/*
> work?
> Justin, what do you think?
Maybe i was not clear enough: tar cBf - bin worked correctly.
I think tar cBF -bin/* would copy the files but not the directory.
> > 3) in Init.sh there are some lines added regarding LD_LIBRARY_PATH
> > i had to remove them (script failing otherwise).
> Could you send the error message? This is required for r.in.gdal.
I do not have easy access to the machine, ill send the error asap.
> > 4) (minor one) configure didn't notice that "ar" was not in my path
> > and libgis.a could not be created... (ar: command not found)
unexperienced
> > users (not that i feel that experienced) may easily get confused.
> Mhh, isn't "ar" usually in the path? Sorry, no idea how to change that.
> Perhaps you just set a link :-)
Just what i did :P
Ciao,
	Federico
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
