[GRASS5] grass cvs snapshot from 26. Feb.
Andreas Lange
A.C.Lange at gmx.net
Sun Mar 4 08:05:52 EST 2001
Hi Markus, Hi all,
thank you very much for the all the useful answers.
I can now compile and use the cvs snapshot on linux, freeBSD and Cygwin.
You have to either do a ./configure --with-socket on a clean source tree
_or_ a
make distclean; ./configure --with-socket; make; make install
and ignore the error with install.
The sockets setup works ok. I can now even fire up X11 on Cygwin, issue bash
and login into grass and start a grass monitor. But this bogs down the
machine extremely and it is very unusual to work in a full-window X11 on Windows
2000.
I will have a look on the IRIX problem another time. Will try the -lsocket
tip first.
But i would ask to fix the install script before making sockets the default
:-). And the socket option to ./README.xdriver should be disabled or echo an
information message that it does not work.
The sockets setup is really great work.
Andreas
> Hi all,
> On Fri, Mar 02, 2001 at 02:39:35PM +0100, Andreas Lange wrote:
> > r.fill.dir does not compile (needs f77/g77, f77 is always found, i think
> > that the detection order should be g77 first, f77 second.)
> I have reordered this in configure[.in] (was requested by Justin as
> well some time ago).
> Hope it's ok,
> Markus
Sent through GMX FreeMail - http://www.gmx.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
