[GRASS5] grass cvs snapshot from 26. Feb.
Eric G. Miller egm2 at jps.net
Sat Mar 3 15:19:21 EST 2001
On Fri, Mar 02, 2001 at 02:39:35PM +0100, Andreas Lange wrote:
> Will the sockets setup be default for the stable
> version?
> The "make install" with the sockets setup dies with
> some error for a missing create_sockets.sh script,
> this happens on Linux, IRIX, FreeBSD and Cygwin, but obviously only
> if ./configure --with-socket is used!
I don't know what this create_sockets.sh is about.  The sockets are
created as needed in the current mapset's .tmp directory.  Just comment
out the line in Makefile.in that looks like:
test ${XDRIVER} != socket && ${SHELL} -c "${SHELL}
${SRCDIR}/src/scripts/shells/create_${XDRIVER}s.sh ${INST_DIR}
2>/dev/null ; true"
I have no idea what the purpose of that is supposed to be, but the
"test" should be protected in an "if test ..." so it doesn't kill
the make when ${XDRIVER} == socket.
> If i issue "bash", next log into grass5 and do a "d.mon start=x0"
> i get the following error message:
> Usage: x0 [nlev]
> No socket to connect to for monitor <x0>
> Trying again
This problem can occur if there's a mismatch with the communications
method.  At the moment, if you do --with-socket for configure, and later
do, --with-fifo or --with-ipc, you have to make sure at least the d.mon
object files are deleted before continuing with "make".  Make can't know
it should recompile some of the d.mon sources as there's a USE_G_SOCKS
define that triggers conditional compilation in d.mon sources when
--with-socket is specified.  This conditional compile was necessary, as
the sockets drivers take at most two arguments (argv[0] and argv[1]),
where argv[0] is the name the driver was invoked as (and will be the
name used in creating the socket file) and argv[1] is the optional nlev
argument -- No paths to "fifos" are needed.
> The other tests in summary:
> Linux, Red Hat 7.0, Kernel 2.2.17-7, i686, gcc 2.96:
> fifo: compiles and works. confirmed.
> ipc: compiles error free and works, confirmed.
> sockets: compiles, d.mon start=x0 does not work.
> Message:
> "No socket to connect to for monitor <x0>
> Problem selecting x0. Will try once more" (twice)
See above about cleaning d.mon and rebuilding it.
> ld32: ERROR 33: Unresolved text symbol "__INTADDR__" -- 1st referenced by
> /disk2/opt/grass.src/src/libes/LIB.mips-sgi-irix6.5/libgis.a(unix_socks.o).
>         Use linker option -v to see when and which objects, archives and
> dsos are loaded.
Bob Covill mentioned something about needing a -lsocket linker option on
a Solaris build.  Maybe the same issue?  Guess we need another configure
check...
> FreeBSD/alpha, 4.2-RELEASE, gcc 2.95.2:
> fifo: compiles and works, confirmed.
> ipc: compiles error free except for NVIZ, works OK, confirmed. Slow.
> Problem with backing store?
> sockets: compiles and installs ok, but does not work:
>  d.mon start=x0
>  Usage: x0 [nlev]
>  No socket to connect to for monitor <x0>.
See above about cleaning d.mon sources first.
> Windows 2000 Professional, 5.00.2195, Cygwin 1.1.8, i686, gcc 2.95.2-6:
> fifo: compiles ok, working not possible
> ipc: compiles ok so far, does not work.
> sockets: does not work.
> (on each machine i did:
> tar xzf grass_src, ./configure; make; make install for default fifo setup
> then:
> ./README.xdriver fifo|ipc|socket ; make ; make install)
Don't do this for sockets. You must do ./configure --with-socket.
Otherwise a symbol needed for d.mon conditional compile will not be
defined.  And, as already mentioned, d.mon sources need to be cleaned of
object files.
Yes, it's all pretty messy right now...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
