[GRASS5] instructions for making binaries
mlennert at ulb.ac.be
Wed May 23 10:55:59 EDT 2001
Markus,
in "release_rules.txt" it says that one should install GDAL and copy it to the
GRASS binaries in /usr/local/grass5/lib. However, if one does a complete
reinstall on GRASS, there is no /usr/local/grass5 before doing a 'make
install' which is mentioned later in the text. Shouldn't this be the other way
around, i.e. make install and then installation of GDAL ?
Moritz
BTW, I get a warning at the very end of the compile process:
cp: cannot stat `src/scripts/shells/create_ipcs.sh': Aucun fichier ou
répertoire de ce type
chmod: getting attributes of `/home/grass/grass5.0.0pre1/dist.i686-pc-linux-gnu
/dev/create_ipcs.sh': Aucun fichier ou répertoire de ce type
This doesn't seem to cause a problem up to now, but what does this mean ?
P.S. Do you want this kind of questions / error message in grass5 or should I
post them to grass-bug ?
