5.0.0pre1 Linux/x86 available - Was: Re: [GRASS5] instructions for making binaries
Markus Neteler neteler at geog.uni-hannover.de
Thu May 24 03:18:56 EDT 2001
Hi Moritz,
many thanks for building the Linux binaries. They are in place now
on the web site - available for testing.
Thanks,
 Markus
PS: I will be offline 'til Sunday.
On Wed, May 23, 2001 at 05:49:36PM +0200, mlennert at ulb.ac.be wrote:
> > Hi again,
> > On Wed, May 23, 2001 at 04:46:44PM +0100, Markus Neteler wrote:
> > > > cp: cannot stat `src/scripts/shells/create_ipcs.sh': Aucun fichier ou
> > > > répertoire de ce type
> > > > chmod: getting attributes of `/home/grass/grass5.0.0pre1/dist.i686-pc-linux-gnu
> > > > /dev/create_ipcs.sh': Aucun fichier ou répertoire de ce type
> > > > This doesn't seem to cause a problem up to now, but what does this mean ?
> > > Mhhh. It shouldn't appear any more as create_ipcs.sh is removed and all
> > > cp's as well. Somewhere we probably missed to remove it. When does it
> > > appear?
> > o.k, I found it:
> > ./src/CMD/generic/POST_INSTALL.sh
> > and have removed it. Glynn, shall we keep the create_fifos.sh there?
> > Moritz: Does it break the installation? Then we have to release pre2...
> > If it is just a warning, we can live with that.
> It doesn't seem to cause any problems up to now. I'm testing right now. d.rast
> works well here (no speed or system resources problems), so does nviz,
> apparently.
> Maybe we should put up a list of modules that we can use as a test suite.
> Preferably with a specific test data set. I don't even know most of the GRASS
> modules, and so a list of mission critical modules to test would be good.
> I'll make the binaries and ftp them in so that others can test them.
> Moritz
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
