[GRASS5] Socket compilation error on HP-UX
Robert Lagacé lagace at grr.ulaval.ca
Tue May 29 18:13:20 EDT 2001
> > > > The <sys/select.h> is missing on HP-UX.  What are the symbols that
> > > > "connec_socket.c" is looking for in this file so I look where they are.
> > > on my linux box it compiles without sys/select.h. Perhaps you try to
> > > remove that include line and compile again. Maybe this is a residual
> > > from a former version?
I remove the the include line and the compilation did not complained
but I do not know the implact.  The XDRIVER is not linked correctly because
/usr/ccs/bin/ld: Can't find library for -lX11.
I need to find the X11 lib.
> > Yep; it's from the original attempt at getting the mouse functions to
> > terminate on EOF (from a couple of days ago). The select() has now
> > moved to Serve_Xevent.c.
> No it isn't; I was getting confused with command.c (which had a
> select() added then removed).
> > However, it appears that <sys/types.h> is the correct file to
> > include.
> This is still true. I'll change this.
What are the symbols or functions defined there?
> Glynn Clements <glynn.clements at virgin.net>
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
