[GRASS5] Socket compilation error on HP-UX
Glynn Clements
glynn.clements at virgin.net
Wed May 30 00:53:58 EDT 2001
Robert Lagacé wrote:
> > > > > The <sys/select.h> is missing on HP-UX. What are the symbols that
> > > > > "connec_socket.c" is looking for in this file so I look where they are.
> > > > on my linux box it compiles without sys/select.h. Perhaps you try to
> > > > remove that include line and compile again. Maybe this is a residual
> > > > from a former version?
> I remove the the include line and the compilation did not complained
> but I do not know the implact.
Removing the line shouldn't cause any problems.
> The XDRIVER is not linked correctly because
> /usr/ccs/bin/ld: Can't find library for -lX11.
> I need to find the X11 lib.
It's normally in "/usr/X11/lib". If it is installed, but the
"configure" script can't find it, you can use the "--x-libraries"
argument to force a specific directory.
> > > Yep; it's from the original attempt at getting the mouse functions to
> > > terminate on EOF (from a couple of days ago). The select() has now
> > > moved to Serve_Xevent.c.
> > No it isn't; I was getting confused with command.c (which had a
> > select() added then removed).
> > > However, it appears that <sys/types.h> is the correct file to
> > > include.
> > This is still true. I'll change this.
> What are the symbols or functions defined there?
The ones for which <sys/select.h> was being used are the fd_set type
and the FD_ZERO and FD_SET macros. In GNU libc 2, these are defined in
<sys/select.h> but that file is included from <sys/types.h>. The
latter is apparently the correct file to include for these
definitions.
Glynn Clements <glynn.clements at virgin.net>
