[GRASS5] Configure and Solaris: small problem.
Glynn Clements glynn.clements at virgin.net
Fri May 18 05:23:08 EDT 2001
Federico Ponchio wrote:
> 2) It seems to compile and install ok, but grass5 does not start
> because of some libz problem. I will investigate further and report,
> unless someone already encountered the problem and can tell me.
> BTW i didn't expected the grass shell not to start because of libz
> problems, as far as i knows only some raster modules needs it...
No, etc/set_data (the program which interactively prompts for
location, mapset and database) is linked against libz, as is anything
which has $(XDRLIB) in the link command.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
