[GRASS5] filenames in GRASS database/r.mask
Markus Neteler
neteler at geog.uni-hannover.de
Fri May 11 06:49:55 EDT 2001
On Fri, May 11, 2001 at 08:54:40AM +0000, Michel Wurtz wrote:
> "Eric G. Miller" wrote:
> > Or, perhaps, we should disallow hyphens in GRASS database files?
> Probably the best solution... in ascii, there is no difference
> between hyphen and minus. Grass has a function for verifying
> the validity of database's file names G_legal_filename() which
> may be updated. It looks actually :
> int G_legal_filename (char *s)
> if (*s == '.' || *s == 0) {
> fprintf(stderr, "Illegal filename. Cannot be '.' or 'NULL'\n");
> return -1;
> for ( ; *s; s++)
> if (*s == '/' || *s == '"' || *s == '\'' || *s <= ' ' || *s > 0176) {
> fprintf(stderr, "Illegal filename. character <%c> not allowed.", *s);
> return -1;
> return 1;
An addition: I feel that "=" is even no allowed character. It can
be specified (on command line), later you run into troubles when
trying to use the map (on command line).
Just my experience,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
