[GRASS5] Output window in tcltkgrass
Justin Hickey jhickey at hpcc.nectec.or.th
Fri May 11 05:19:10 EDT 2001
Hi Markus
Markus Neteler wrote:
> a small sidenote: I have added this percentage output due to the
> changes in XDRIVER - when drawing large maps, you may wait a few
> seconds until the image is draw completely in one step. In past, with
> line-by-line drawing in d.rast the user has been seeing what's
> ongoing. To avoid confusion, d.rast chats now.
Yes, I agree that the percentage output needs to stay as it is very
crucial as you point out. I just want to change the GUI in tcltkgrass.
> However, these left-over windows (some other modules are affected,
> too), are quite inconvenient. Maybe the messages could be directly
> printed into a tcltkgrass module window?
> |        d.rast               |
> |Raster map to be displayed:  |
> |  ______________ raster      |
> |o Overlay                    |
> |d.rast_____________________  |
> |     New message board       |  <- here all related messages should
> +_____________________________+     appear instead of opening another
>                                     window.
> This would definitly improve the optical impression of tcltkgrass.
This is a good idea! I think I could change it without too much trouble
if somebody could point me to the correct place in the code to make
these changes.
> > The proper thing to do would be to have d.rast pop up a process
> > indicator (I think there is one in bwidget) that is destroyed when
> > complete but I'm not sure how much work that would be.
> Question is how the G_percent() communicates with external modules...
I know how to do this. It is the same technique I will use with the new
initialization code. Basically, separate the interface from the code. So
where G_percent calls fprintf() we replace with something like
DisplayPercent() which will do the proper thing (call fprintf or a
Tcl/Tk function) depending on the current interface. However, I would
not propose this change until 5.1.
So, can anyone give me some pointers in changing the module windows in
tcltkgrass?
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
