[GRASS5] filenames in GRASS database/r.mask
Andreas Lange
Andreas.Lange at Rhein-Main.de
Thu May 10 06:45:38 EDT 2001
i noticed two minor problems:
some modules (at least r.mapcalc) do not allow dashes (-) in filenames
or at least need different quoting/treatment. I noticed this with
shade.rel.sh and shade.clr.sh, which choked on my raster files with
dashes. I changed both scripts to exit with an error message with files
with dashes in, i know of no solution.
This should be put into the TODO to revise this for 5.1. Every module
should work with allowed filenames.
Second i am missing a commandline version of r.mask. This should be
really simple, only a reclassified raster map of name "MASK" must be
created or deleted. But the code of r.mask is mixed up with the code for
r.reclass, so i have not done it.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
