[GRASS5] [bug #262] (grass) v.digit: implement circle cursor for snapping distance
Request Tracker grass-bugs at intevation.de
Fri May 4 12:29:49 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=262
Subject: v.digit: implement circle cursor for snapping distance
Wish:
It would be very convenient to have a circle cursor in v.digit implemented
which displays the current snapping distance while digitizing.
Means: a circle is drawn around the mouse cursor in map with snapping distance
as diameter. This needs to be sensitive to the current zoom level.
Thanks,
Markus
-------------------------------------------- Managed by Request Tracker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
