[GRASS5] i.composite problems verified
Andreas Lange
Andreas.Lange at Rhein-Main.de
Wed May 2 10:22:26 EDT 2001
Hi Glynn and Eric,
i vote for removing the paint drivers. But i noticed that some functions
are implemented in the paint driver that are currently missing in the
ps.map program, e. g. point, setpat, defpat. And i think that site and
raster legends (slegend, rlegend) are missing (compare vlegend
command!).
One general consideration should be that creating printed maps and
creating maps for screen viewing/world wide web is very different. So a
single architecture for display and hardcopy output has drawbacks.
I currently have some problems with ps.map ps output and ps2pdf on linux
(on cygwin it works!). Will work on this later on.
cu,
Andreas
Glynn Clements wrote:
> Eric G. Miller wrote:
> > > I've also added "r.out.ppm3", which creates a PPM image from red,
> > > green and blue map layers.
> > > The main components which are still missing[1] are RGB versions of the
> > > "raster" command for p.map and ps.map. I'll look into ps.map next.
> > > The paint system seems to only support paletted raster data, and only
> > > 256 colours at that. Is it still in widespread use? There aren't many
> > > drivers (13, or 9 if you exclude NULL, ppm, preview and preview2).
> > > Wouldn't it be better to scrap "paint" and just point people at
> > > Ghostscript? Any updates to the paint architecture would presumably
> > > require developers who have access to the technical specs of all of
> > > these printers (or, at least, all of the ones which would still work
> > > after an interface change).
> > I'd vote for scrapping the "paint" routines and putting efforts into
> > ps.map. But maybe it'd be good to poll the user community first...
> In the slightly longer term, it would be nice to go a step further,
> and have a single architecture for display and hardcopy output.
> Glynn Clements <glynn.clements at virgin.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
