[GRASS5] XDRIVER colour changes
Markus Neteler neteler at geog.uni-hannover.de
Wed May 2 09:50:05 EDT 2001
On Wed, May 02, 2001 at 01:43:29PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > the solaris compile is done. At least working remote on solaris
> > fails:
> > d.mon x0
> > ncolors: 65536
> > (sometimes I get:
> > Can't bind to socket for monitor <x0>. Already in use?
> This message is from the old (pre-merge) version (SWITCHER.c):
>         fprintf (stderr, "Can't bind to socket for monitor <%s>. "\
> 			"Already in use?\n", me);
> The new version has a slightly different message:
> 	fprintf(stderr, "Can't bind to socket; already in use?\n");
> (I couldn't be bothered passing argv[0] all over the place just for
> use in error messages).
> I'll ignore the rest of the message unless you tell me that it happens
> with the new version.
Glynn,
my apologize: It seems that an old lib*.a has been used. After cleaning
and rebuilding the Xdriver runs well on Solaris2.6/SUN.
Thanks for your hint,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
