[GRASS5] [bug #825] (grass) r.poly doesn't write label points correctly
Request Tracker
grass-bugs at intevation.de
Thu Nov 8 17:25:53 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=825
Subject: r.poly doesn't write label points correctly
Platform: Linux/Intel
grass downloaded at: CVS Server, Germany
grass sources source: yes, I am using the latest GRASS from CVS
obviously r.poly doesn't calculate the label point positions
correctly (stored in dig_att) which leads to label problems.
It even fails with a simple test pattern:
Generate test pattern:
r.mapcalc testpat="if( (10*sin(2*row()) + 10*sin(2*col())) > 0.,null(),1)"
d.rast testpat
r.poly in=testpat out=testpat
v.support testpat
-> warning PNT_IN_AREA appears which shouldn't
When converting the dig_att/testpat to a sites list, the
label positions are quite strange.
I would expect the centers of the pattern.
d.erase
v.to.rast in=testpat out=testpat2
d.rast testpat2
-> one pattern is missing
It would be nice to have that fixed...
Markus
-------------------------------------------- Managed by Request Tracker
