[GRASS5] [bug #826] (grass) d.save does not recognize region settings
Glynn Clements
glynn.clements at virgin.net
Fri Nov 9 06:33:51 EST 2001
Request Tracker wrote:
> d.save -a and d.save do not recognize/save the current region settings.
d.save works fine. The problem is that d.erase removes the "m_win"
property from the monitor. The property will only be restored when
something calls D_check_map_window(), either directly or via D_setup()
or Dcell().
Maybe d.erase should call D_setup()?
Glynn Clements <glynn.clements at virgin.net>
