[GRASS5] [bug #838] (grass) g.mremove goes beyond promised current mapset
Request Tracker
grass-bugs at intevation.de
Fri Nov 16 10:33:02 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=838
0grass$ g.mremove help
Description:
Removes data base element files from the user's current mapset.
>>>>>>>>>ok, it says "current mapset"
1grass$ g.list type=rast
raster files available in mapset jidanni:
aiw250 cost m530 pipeline sites
arabl_ind cost_dist main_roadbuf pipeline2 sites2
asp1 crashbuf main_roadbuf2 pipelinestream sites3
asp_cost crashbuf_tmp main_roads pipelinestream2 slope1
asp_north flat mway polrivers urbanbuf
asp_south gradeIII mwaybuf railbuf urbanbuf2
at_risk lan_cost mwaybuf_temp railbuf_temp v1
avheight m4 pipe2 site v2
buffers m5 pipe_final site2 w250
raster files available in mapset PERMANENT:
contours image plant rail segment spillage urban
crash landcov popln roads source topo water
0grass$ g.mremove rast='*'
g.remove
rast=aiw250,cost,m530,pipeline,sites,arabl_ind,cost_dist,main_roadbuf,pipeline2,sites2,asp1,crashbuf,main_roadbuf2,pipelinestream,sites3,asp_cost,crashbuf_tmp,main_roads,pipelinestream2,slope1,asp_north,flat,mway,polrivers,urbanbuf,asp_south,gradeIII,mwaybuf,railbuf,urbanbuf2,at_risk,lan_cost,mwaybuf_temp,railbuf_temp,v1,avheight,m4,pipe2,site,v2,buffers,m5,pipe_final,site2,w250,contours,image,plant,rail,segment,spillage,urban,crash,landcov,popln,roads,source,topo,water
>>>>>>>>>>> there last few files are not in the current mapset!!!
Did you mean this(y/n)?
n
>>>>>>>>>>>> also it doesn't say what happens if i just hit RET: [y]
>>>>>>>>>>>> or [n] defau;t action?
--- Headers Follow ---
>From neteler at itc.it Fri Nov 16 16:33:02 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 003C5139CC
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:33:01 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFX1f23431
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFX0d19168
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:33:00 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFWxE18162
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:32:59 +0100 (MET)
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFWxw29545
for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:32:59 +0100
Resent-Message-Id: <200111161532.fAGFWxw29545 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMME16731
for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:25 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMHd18879
for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:19 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id 23C6716E0; Fri, 16 Nov 2001 22:48:20 +0800 (CST)
To: Markus Neteler <neteler at itc.it>
Subject: g.mremove goes beyond promised current mapset
Reply-To: jidanni at yahoo.com.tw
Date: Fri, 16 Nov 2001 22:48:19 +0800 01:00:00 +0000 (GMT)
Message-ID: <m28zd622mk.fsf at Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:32:59 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
