[GRASS5] [bug #839] (grass) g.mremove
Request Tracker
grass-bugs at intevation.de
Fri Nov 16 10:33:11 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=839
now way to restrict mapset...
e.g. rast=* will also match PERMANENT layers
--- Headers Follow ---
>From neteler at itc.it Fri Nov 16 16:33:10 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 5EEE9139CC
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:33:10 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFX9f23446
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:33:09 +0100
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFX8d19172
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:33:08 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFX8E18167
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFX7Y29550
for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:33:07 +0100
Resent-Message-Id: <200111161533.fAGFX7Y29550 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMdE16828
for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:46 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMZd18954
for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:36 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id 2D4C016DF; Fri, 16 Nov 2001 22:41:27 +0800 (CST)
To: neteler at itc.it
Subject: g.mremove
Message-Id: <20011116144127.2D4C016DF at localhost.localdomain>
Date: Fri, 16 Nov 2001 22:41:27 +0800 (CST)
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:33:07 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
