[GRASS5] [bug #843] (grass) no r.mapcalc help
Request Tracker grass-bugs at intevation.de
Fri Nov 16 10:39:42 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=843
$ r.mapcalc help
you have confused me
--- Headers Follow ---
>From neteler at itc.it  Fri Nov 16 16:39:42 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
	by lists.intevation.de (Postfix) with ESMTP id C7BE7139CC
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:39:41 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFdff23950
Received: from artemide.itc.it (artemide [10.0.10.10])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFded19382
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:39:40 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFdcE19176
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:39:39 +0100 (MET)
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id fAGFdbI29626
	for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:39:37 +0100
Resent-Message-Id: <200111161539.fAGFdbI29626 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMbE16815
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:43 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMVd18945
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:31 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
	id D5A7916DC; Fri, 16 Nov 2001 22:00:05 +0800 (CST)
To: neteler at itc.it
Subject: no r.mapcalc help
Message-Id: <20011116140005.D5A7916DC at localhost.localdomain>
Date: Fri, 16 Nov 2001 22:00:05 +0800 (CST)
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:39:37 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
