[GRASS5] [bug #842] (grass) r.stats uglyness on screen
Glynn Clements glynn.clements at virgin.net
Fri Nov 16 12:10:35 EST 2001
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=842
> look how the stderr and stdout combine to make a mess on ones terminal:
If run with "-q", nothing should be printed to stderr.
Maybe "-q" should be assumed if stdout is a tty?
Glynn Clements <glynn.clements at virgin.net>
