[GRASS5] [bug #845] (grass) r.reclass and * = 0
Request Tracker grass-bugs at intevation.de
Fri Nov 16 10:40:03 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=845
Why doesn't my line "* = 0" work like in the manpage?  Why instead "no data"?
s$ g.version
GRASS 5.0.0pre1 (May 2001)
0grass$ r.report -qh landcov  units=c
|                         RASTER MAP CATEGORY REPORT                          |
|LOCATION: leics                                      Fri Nov 16 15:30:05 2001|
|          north: 322000    east: 449750                                      |
|REGION    south: 316000    west: 444000                                      |
|          res:       50    res:      50                                      |
|MASK:none        |
|MAP: Land Cover / Land Use (landcov in PERMANENT)                            |
|                         Category Information                          | cell|
|#|description                                                          |count|
|1|Industry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . |  343|
|2|Residential. . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 1317|
|3|Quarry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . |   50|
|4|Woodland . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . |  117|
|5|Arable . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 7891|
|6|Pasture. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 2906|
|7|Scrub. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 1041|
|8|Water. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . |  135|
|TOTAL        |13800|
0grass$ cat in
6 7 = 1
* = 0
end
0grass$ r.reclass input=landcov output=gradeIIIa  title='Grade III agricultural land' < in
0grass$ r.report -qh gradeIIIa units=c
|LOCATION: leics                                      Fri Nov 16 15:30:46 2001|
|          res:       50    res:      50                                      |
|MASK:none        |
|MAP: Grade III agricultural land (gradeIIIa in jidanni)                      |
|1| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 3947|
|*|no data. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . | 9853|
|TOTAL        |13800|
--- Headers Follow ---
>From neteler at itc.it  Fri Nov 16 16:40:02 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
	by lists.intevation.de (Postfix) with ESMTP id 8853D139CC
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:39:57 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFdvf23970
Received: from artemide.itc.it (artemide [10.0.10.10])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFdtd19403
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:39:56 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFdrE19224
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:39:54 +0100 (MET)
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id fAGFdqH29636
	for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:39:52 +0100
Resent-Message-Id: <200111161539.fAGFdqH29636 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMNE16738
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:25 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMHd18878
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:19 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
	id 824C416D3; Fri, 16 Nov 2001 15:36:14 +0800 (CST)
To: Markus Neteler <neteler at itc.it>
Subject: r.reclass and * = 0
Reply-To: jidanni at yahoo.com.tw
Date: Fri, 16 Nov 2001 15:36:14 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2bsi34175.fsf at Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:39:52 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
