[GRASS5] [bug #846] (grass) why did label etc. for first site disappear?
Request Tracker
grass-bugs at intevation.de
Fri Nov 16 10:40:21 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=846
0grass$ r.stats -a -l sites3
r.stats: 1 Pot. site 1 30000.000000
2 Pot. site 2 62500.000000
3 Pot. site 3 82500.000000
* no data 34325000.000000
0grass$ r.poly input=sites3 output=vect_sites
Opening files
Performing extraction
Consolidating area information
Closing files
0grass$ v.support map=vect_sites option=build
V.SUPPORT:
Selected information from vector header
Organization: organization
Map Name: mapname
Source Date:
Orig. Scale: 24000
No snapping will be done
Reading Vector file.
100%
Building areas
Building islands
Attaching labels
PNT_TO_AREA failed: (447975.000000, 318475.000000) (Category 1)
Number of lines: 3
Number of nodes: 3
Number of areas: 3
Number of isles: 3
Number of atts : 2
Number of unattached atts : 1
Snapped lines : 0
0grass$ v.report type=area map=vect_sites
Loading vector information.
Processing area 3
| VECTOR MAP CATEGORY REPORT |
| north: 322000 east: 449750 |
|WINDOW south: 316000 west: 444000 |
| res: 50 res: 50 |
|MAP: vect_sites in jidanni |
| Category Information |
|#|description |
|0| |
|2|Pot. site 2 |
|3|Pot. site 3 |
0grass$ $ v.dump -a map=vect_sites|egrep lab\|area:
Loading <vect_sites> vector information.
Processing .....
label: [Pot. site 3 ]
area: 112500.00
Finished <vect_sites>
label: [Pot. site 4 ]
area: 55000.00
label: [Pot. site 5 ]
area: 62500.00
label: [(null)]
area: 82500.00
wow... even less remains!
By the way:
$ fgrep ignore. man/man1/*
man/man1/v.support.1: ignore.
this is should be "ignored". Proof: try grep ignore man/man1/*
--- Headers Follow ---
>From neteler at itc.it Fri Nov 16 16:40:20 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 9341B139CC
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:40:20 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFeKf23991
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeGd19444
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:40:16 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFe9E19297
for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:40:13 +0100 (MET)
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFe8q29641
for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:40:08 +0100
Resent-Message-Id: <200111161540.fAGFe8q29641 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMVE16784
for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:36 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMPd18910
for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:26 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id B98C116DA; Fri, 16 Nov 2001 21:32:39 +0800 (CST)
To: Markus Neteler <neteler at itc.it>
Subject: why did label etc. for first site disappear?
Reply-To: jidanni at yahoo.com.tw
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
Date: Fri, 16 Nov 2001 21:32:39 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2vgga264o.fsf at Mdan.jacobson.tw>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:40:08 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
