[GRASS5] [bug #853] (grass) v.digit fixed (and another wish and a bug)
Request Tracker
grass-bugs at intevation.de
Sat Nov 17 08:24:56 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=853
I think I have fixed the "NOTE: 1 new node needed" bug in v.digit.
The problem was that the number of points needed for snapped lines
was not reduced in
libes/vect32/diglib/check_node.c
(fixed). Radim, can you update for the grass51/ library?
Additionally I have
- improved the related messages in v.digit (feel free to modify again)
- changed to always get a threshold recommendation when entering a
unacceptable snapping threshold (was restricted to digitizing boards)
Please test the fixes (compile the diglib first).
Now a wish: Is it possible to make the cursor center in v.digit transparent?
That would be a great help when digitizing polygons and setting the last =
first point.
Another bug not yet fixed is:
When digitizing areas, the internal line type seems to stay "line", not
area for the category labels. Also the label point is not correctly set
for areas when using the auto-label feature: the point is on the
area border, not within the area (will cause topological troubles).
This must be fixed in my opinion.
Cheers
Markus
--- Headers Follow ---
>From neteler at itc.it Sat Nov 17 14:24:56 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id CFF0813A02
for <grass-bugs at intevation.de>; Sat, 17 Nov 2001 14:24:55 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAHDOtf04393
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAHDOnd12726
for <grass-bugs at intevation.de>; Sat, 17 Nov 2001 14:24:49 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAHDOmE18208;
Sat, 17 Nov 2001 14:24:48 +0100 (MET)
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAHDOlf02074;
Sat, 17 Nov 2001 14:24:47 +0100
Date: Sat, 17 Nov 2001 14:24:47 +0100
To: grass5 developers list <grass5 at grass.itc.it>
Cc: grass-bugs at intevation.de
Subject: v.digit fixed (and another wish and a bug)
Message-ID: <20011117142447.A2069 at itc.it>
Mail-Followup-To: grass5 developers list <grass5 at grass.itc.it>,
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
-------------------------------------------- Managed by Request Tracker
