[GRASS5] [bug #856] (grass) fft unresolved at link time
Glynn Clements
glynn.clements at virgin.net
Wed Nov 21 02:18:53 EST 2001
Request Tracker wrote:
> grass sources source: no, I got a source code package from the server, 5.0.0pre2
> fft reference is unresolved at link time resulting in i.fft, i.zc,
> i.surf.fractal and i.shape not created. Below is the linker output:
You need the FFTW library, from www.fftw.org.
The current (CVS) version of the "configure" script will report an
error if FFTW cannot be found.
I guess that we should release a -pre3 version. The current configure
script is (or, at least, should be) a lot more robust than the -pre2
version.
Glynn Clements <glynn.clements at virgin.net>
