[GRASS5] [bug #860] (grass) r.sunmask does not compile properly under Irix 6.5
Request Tracker grass-bugs at intevation.de
Tue Nov 27 11:31:25 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=860
Subject: r.sunmask does not compile properly under Irix 6.5
Platform: SGI/Irix
Xwindows version: Xfree 3.3.6
Xwindows manager: Enlightment
TclTk version: tcl/tk 8.3
grass downloaded at: Baylor site
grass binary for platform: I compiled the sources myself
grass sources source: no, I got a source code package from the server, 5.0.0pre2
c compiler name: gcc
r.sunmask appears to compile properly, except for a few warnings:
ld: WARNING 84: /usr/local/gisware/gis/grass/src/grass5.0.0pre2/src/libes/LIB.mips-sgi-irix6.5/libdatetime.a is not used for resolving any symbol.
ld: WARNING 84: /usr/gnu/lib/gcc-lib/mips-sgi-irix5.3/2.7.2.2/libgcc.a is not used for resolving any symbol.
These appear at the end of compilation. When run, r.sunmask returns "ERROR: program 'r.sunmask' cannot be executed because: Neither a command
       line (cmd) or interactive (inter) version was found"
Thanks,
	Dave
-------------------------------------------- Managed by Request Tracker
